PaulRainbow
Disagree on the Both setting. If Both was for emergencies only then a VSR would be pointless as its entire function is to toggle between 1 and Both.
A VSR just does automatically what a 1-2-B does manually when used well.
The merits of automatic versus manual is a whole other topic.
Which part of "using it for routine charging leaves the operator vulnerable to flat batteries in certain failure cases, or if he should forget to switch it back later. " is incorrect ?
