Paul_S123
I know what Bruce means . It's not as clear cut for some depends on how optimised the particular hull is
. Some will fair better @ D compared to P than others more so if the motors are on or near the "edge" power and thus burn rate when planing
My maths give a marginal saving but not really bothered as it depends on the conditions.
Only D of calm and flat . In a sea chop best to P
My favourite anchorage for a swim is 6 miles one way .
D at hull speed 8.3 @ 15 L/h or 9.3 @ 18 L/h
Plotter says 45 mins so 3/4 of the L/h 12 to 14 L used
On way each motor
P @ 27 knots plotter says 12 mins so 20 % of 1 h @ 90 L/H so 18 L burned in 11 /12 mins as opposed to 12/14 in 45 mins
X all by two
If it's rough and choppy then all done n dusted in 11/12 mins
And over time if D becomes more norm there's hours put on 11/12 mins compared to 45 - 4 x the hours
You can extrapolate up for longer passages . Sure there's a saving but is it that big to sacrifice 27 knots to 8 or 9 ?
I don't think so with my boat .
This is because they are only doing 1750rpm when WOT is 2150 .
Obviously at 2000rpm the burn rate is north of 200L /h
Real figure not internet btw .I don't need to push it as most other 14 M boats like the FL T47 and S/Ske Porto 46/57/48 have D9 or VP 74 at 575 hp or worse still 480 hp.
I have 700 hp motors which I can run at an economic rpm for a given speed
Those 575 boys above will be at a steep part of the consumption curve keeping up with me @27 knots .
So my maths makes it for the 6 miles you cruise to:
D at 8.3 knots at 30 litres per hour: 21.68 litres used
P at 27 knots at 180 litres per hour: 40 litres used
Probably insignificant on the 13 minute cruise like you do...but over a few hours it's a huge difference...even if you just take there and back it's saving about 37 litres on a tiny journey.
