galeus
As a back up to our trusty BMC 1.5 diesel we have a 10hp o/b electric start that is raised and lowered in the water by an actuator.
http://www.youtube.com/watch?v=OnyXMznqpwY
http://www.youtube.com/watch?v=3rlTeRJ1-mA
This actuator is not designed for marine use so I have done my best to marinise it, but it is not perfected yet.
It is actually the second unit and in it's third year.
At this point in time it is trying to work ie I can see the torque trying to move the o/b bracket but no good, so I will bypass the actuator and operate it by rope and gravity if needed
until the end of our trip.
Question. Inside the unit as well as the motor and 'screw jack' type mechanism is a circuit board which last winter when I serviced it had signs of corrosion, but it still worked.
Do you think the actuator would work without the circuit board, if I wired straight to the the motor and operated the switch very deftly, (so as not to blow a fuse).
Anything that makes it simpler would surely make it more reliable.
Thanks Richard
Thanks Richard
