Acetal for engine mount shims .
IanCC
14 Oct 2019
Seems like a good idea to me, no rust and all that. But are they a bit slippy, or will torqued down engine mount bolts take care of that? I have visions of the engine vibrating itself out of alignment.
Thanks for thoughts.
Daverw
2 Nov 2016
Humber
Most plastics compress over time, I’ve be aligning electric motors for years and only use SS or brass sheet for shims, why use anything else? Especially when your mounting something that try’s to bounce around
IanCC
14 Oct 2019
Why? Because it doesn't corrode, is easy to work and not too expensive.
If it's cut to fit the whole of the underside of an engine mount it would suprise me if it compressed. I need 20mm thick so buying and cutting stainless, not cheap. Appreciate your thoughts btw.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
Acetal is a thermoplastic, which means it will deform under heat/load. Its creep strength is stated to be good but it cannot compete with a metal.
Stainless steel would be difficult to DIY in this thickness but aluminium would be a satisfactory substitute.
IanCC
14 Oct 2019
Thanks for input. Google tells me acetal good for continuous operating temp of 115C. And very stiff and good dimensional stability. Also unaffected by repeated heating and cooling. My alternator is limited to 100C. Also oceonflex cables will melt before then i think.
penfold
25 Aug 2003
On the Clyde
Bad idea unless you're using it temporarily to get the right packing thickness to then get a packer made from steel. It's not dimensionally stable enough.
Poignard
23 Jul 2005
South London
If rust is the only objection to using mild steel shims, I wouldn't worry. The engine mounts are mild steel, and there's plenty of other steel components on an engine that can rust, yet you presumably don't worry about them.
You could always use brass shim if you wished, or even stainless steel.
But in post #5 you say you need a shim 20mm thick! That's not a shim, that's a spacer.
Something wrong if you need to take up that distance.
Daverw
2 Nov 2016
Humber
Agree 20mm stainless plate not cheap and small off cuts not readily found but 10mm easy to get as common used for webs etc, and just double up.
acetal yeas has very good dimensional stability but will still compress, even a fraction of mm will loosen fasteners
IanCC
14 Oct 2019
Thanks for reply. Do you have some figures for that? And/or what are you basing your opinion on. Most sources i find say it is particularly dimensionally stable.
Weaknesses seem to be chlorine and mineral acid.
Polyoxymethylene - Wikipedia
IanCC
14 Oct 2019
Good points, thank you. My mounts are Aluminium. Not much rust. So they are spacers nit shims. It is what it is if i want the shaft down the centre of the tube and the height in the r&d miunt to be within tolerance.
IanCC
14 Oct 2019
I have tried to find stainless offcuts locally but no joy. It has 10mm mild steel packers at present but needs 20mm, so was hoping to bin the current ones.
Daverw
2 Nov 2016
Humber
I would use spacers rather than extended studs, most av mount manufactures have max thread spec which can be quite short.
Daverw
2 Nov 2016
Humber
A couple of months ago got 800x75x10mm 316l bar from waste bin at a fabrication company that makes conveyors, paid £10
