jonathankent
What a [--word removed--] of a day..... well it all started well, lovely clear blue skies, a very gently breeze, getting ready for our club race.... and for starters the tide is slower at coming in than normal, so a delayed boarding and potential late start of the race.... not too much of a problem, but niggling.
Then... got the boat all ready for the off, tried starting the outboard and it didn't want to play... found the cause, the fuel line not fully connected properly.... so got it started..... then no water cooling coming out the pee hole! /forums/images/graemlins/mad.gif just the odd drop, not the usual stream, even when increasing the revs it didn't improved, just dripped a bit more often..... [--word removed--] it - thats the race over then - can't go out on an almost windless day not knowing I can rely on the engine!
So, to the problem.... no water cooling passing through the engine. I imagine this is salt build up, or possibly something once living crawled up in there.... the outboard is left on the well all the time and has been anode protected for this. I haven't actually been out and used the engine for about 6 weeks (not had much time /forums/images/graemlins/frown.gif) but 2-3 weeks ago I did start it and let it run for 5 minutes or so. Do you think I am probably right in thinking some sort of buildup? Anyone any clever ideas on how to rectify this, without dismantling the whole thing? Any solutions I could use that could be pumped in to dissolve the buildup? Failing all that, I suppose I would have to strip it all down, check water pump & replace impeller, and try again, but as I have no experience with the mechanics of an outboard, and no manual (yet...), I would rather not have to if there is something else I can do.
Your help, as always, gratefully received.
P.S. the engine is a 1980s Honda 7.5hp
