owen
is it possible to tell the difference between different grades of stainless or does one just rely on the supplier/manufacturer??
This problem of identifying whether the grade of stainless is correct is a daily routine in manufacturing equipment for the offshore oil business (where I work). It is resolved by what is called "Positive Material Identification" (PMI for short). Using a pistol-like device you get a reading of the chrome (and other elements) content which is accurate enough to distinguish 316 from 304, etc. PMI is rroutinely specified to be performed on receipt of materials and also later on in the manufacturing (building) process, to ensure correct materials at the latest possible stage. Unfortunately, the PMI analyser is quite expensive and also emits X-rays, requiring operator certification in most industrial environments. Not much help for the individual boater, I'm afraid, but at least you now know that you are not alone with this problem!
A1, A2, A4 etc are specifications for grades of austenitic stainless steel that correspond to types 303, 304, 316 but the only thing that needs to concern you as a yottie is A2 vs A4. The latter doesnt discolour in salt water whilst the former does so. But the discoloration is cosmetic for the most part
You are right of course Vyv , but the reality for most yotties using A2/ 302/304 above deck is that the only problem they have is surface discoloration / rust. Which usually surprises them because they assume that stainless cannot rust. As for 317 I cannot remember ever supplying that to any fastener maker. If 316 wasnt adequate the next step usually was nickel alloys. OK it some years ago now but I seem to remember 317 mainly going as MIG welding wire but I could well be wrong.
