superheat6k
So this morning my stbd engine overheated and stopped itself without warning. See thread on PBO forum if interested.
I had been doing a brief full power run for ~ 5 minutes and was just backing down to a slow cruise, when the engine literally died and all the alarms went off. There was no overheat warning until the engine stopped itself. This was likely due to at least one piston seizing in its bore.
So on returning to the lower helm position from the flybridge, the first thing I noticed was the engine room camera showing a completely grey haze.
I grabbed a foam extinguisher and slowly opened the hatch ready to fire in case there were flames. Neither of the two auto extinguishers had operated and there was no fire, just lots of hot dirty grey steam, and a bilge full of coolant.
I then decided to make a Pan Pan call to Solent Coastguard to inform them of my possible plight as although there was no obvious fire I remained concerned a fire could erupt.
The port engine was still running and this was clearing the fumes.
So ...
1 Was I right to gingerly open the hatch ?
This did immediately establish there was no fire, but had there been a fire this could have made it a whole lot worse.
The fire extinguisher I had to hand is a foam and not a dry powder, so would be more effective, and I would expect the engine room units to fire if flames had been present.
2 When I then called the Coastguard they followed their play list - how many aboard, are life jackets being worn - they were being put on as the family were all still in the cabin, Position ???
Life jacket rule on our boat is on when on the oopen deck and slipped, but only to be worn inside if the weather deteriorates badly, or when a situation arises like it did today. We do keep the LJs immediately out and available, with each person having their own pre-adjusted to fit correctly. They are also serviced annually.
3 I hadn't bothered turning on the plotter below - only a short hop from Portsmouth to the Hamble. So I couldn't advise my proper position. However, the plotter on the FB was on so I was able to report my proper position a couple of minutes later once I turned on the C120 repeater.
4 Neither had I put out the paper charts.
5 I forgot to open the separate compartment to shut off the fuel supply to the stbd engine. However, had there been flames I would have pulled the emergency lever cutting fuel to both engines. The Pan Pan would have immediately become a Mayday, via Radio and Flares - indeed I would likely have beached the boat on the nearby Meonshore.
On a plus point it was fine day, and the sea was flat calm. We do carry a life raft and the dingly was inflated on the stern. However, I do feel bad for overlooking some basic pre-sailing checks and preps inasmuch as I had not turned on the plotter in the cabin and hence could not properly report my position.
Now for what looks like will be an expensive engine repair ! Hey ho.
So ...
