eise
Active Member
James,
In the August 2004 edition of YM contained a boat test you had done on the, then, new Legend 33.
The following is a copy of a letter e-mailed to Luhrs.
I have spent the last week (5-11August, 2006) sailing in company with a Legend 33 owned by a friend of my Son in Law. During that time it was crewed by my Son in Law,( who is co- Owner, with me, of a Westerly Konsort)and another experienced person, as the owner had limited sailing exoerience.. Both commented on the boats inclination to power up to windward in a gust( Winds were mainly3/4 but up to 5/6) the general conclusion was she was unbalanced,the main appeared to overpower the foresail.
I sailed it on the final day and initially thought, and suggested, that she ought to have a genoa, to balance the main, as they were leading the foresail sheets through the outboard tracks However I spotted the inboard coachroof tracks and suggested we try leading the sheets through them, having done so she sailed perfectly.
I have looked at your website and can only find this,
Aft Mounted Jib/Spinnaker Winches w/Deck Tracks
Are these what I assumed to be Genoa tracks? If so when would you lead the jib sheets through them, and how would you use them with a spinnaker?
( Have since realised that an American Spinnaker is equivalent to our Cruising Chute so SORTED )
Secondly the S/T winch to the Stbd of companionway (used to hoist Mainsail and control Mainsheet) required, in my opinion, excessive force in order to perform either function, in fact the owner said they had broken a winch handle trying to use it at one time, so now used a longer one in order to get more leverage.
The owner has in fact put roller slides on the sail where the batten pockets are, in the hope of making hoisting easier, with no effect.
Likewise the ratio of the mainsheet blocks seems very small compared to that on my Konsort, but as the winch is common to both systems perhaps that is the problem.
I would be glad of your comments regarding the above as I believe that there is potential for a serious incident as the boat is set up now, especially as the owner has limited sailing exoerience.
I can , you you wish, supply Owners details if you are concerned. I do know that the boat was one of the first sold in the U.K.
The boat referred to above WAS THE BOAT YOU TESTED !!
I must say a verbal reply wasn't very helpful. RE-Mainsail hoisting/Hard winching -Was the kicker off?mainsheet uncleated etc.
Someone else has suggested that the main is heavy and that is why it is difficult to hoist.
Did you find the main difficult to hoist?
I have since discovered this site
http://www.sailingmagazine.net/boattest_hunter33.html
Where the Hunter 33(the American Legend 33) is boat tested.
Speciffically read Para 5 Last Sentence and Para 7 2nd Sentence.
Whwn you tested the boat did you use the inboard tracks, which are basic? If not ,why not? Was the boat ready set up for you?I ask because in the large heading photo of your article you are using the outboard ones.More importantly, did you change from inboard to outboard track when bearing away. Finally, the sail plan is designed to use the inboard tracks, if you had used themm then surely her windward performance would have been better than you have indicated in your article.
Would be pleased to receive your reply to all the above.
If you are further interested, have a look at http://www.sailboatowners.com/forums/pviewall.tpl?fno=1&uid=F&sku=2006230102405.73
http://www.sailboatowners.com/forums/menunew.tpl?fno=2&uid=F
