chuns
Thinking about AIS, I felt motivated to try and develop a quick and simple method of determining whether another vessel (say in a channel crossing) represented a collision risk. I certainly found a way of doing it graphically on the chart, but wondered if there was a mathematical way of doing it. Certainly my Maths ‘O’ level of 45 years ago was insufficient for the task.
So, if you know the range and bearing of a vessel, and you know its speed and COG, and, of course, know your own, is there a mathematical formula which can tell you if you will meet at the same point?
I appreciate that that probably is not enough (for example you might need to know how close it would miss) or whether it passes ahead or astern, but it might be a good starting point.
Can it be done?
Can it be done?
