A cruise from Gravesend to Kingston
I’ve used simple rectangles to draw the main tank, now put a slight v shaped bottom on it with the outlet in the centre of the v
It's a good principle. Does rely on regular maintenance but at the end of the day you can't really argue with it. However I will, in the next post.
Those Dutch people do seem to know a bit about boats.
I'm not quite sure why the day tank is where you take the fuel from though.
Surely if it works as a drain for water and dirt it's best left for that purpose and it would be better to draw fuel from the main tank.
It definitely makes sense to have a separate "sump" for all the rubbish to go but if it's a small tank and the boat starts moving about a lot then even a small amount of water or dirt is going to form a higher percentage of the suspended particles and compromise the filter.
On the other hand if the sump tank (definitely a good idea) was dedicated for waste removal and you take fuel from the main tank then it should be ok.
Also what does the boat safety say about this ?
Boat safety inspection just completed, no problem. Both tanks are steel and welded into the boat with copper (?) fuel pipe.
All I can add is, I’ve never had a problem when going downstream.
I change my fuel filters every year and they are always clean. I do always use a maintenance dose of diesel bug treatment whenever I add fuel and I always fill the tank at the end of the season. I also always carry at least two spare Racor and fine filters on board, but have never had to use them.
Im planning some coastal cruising this year, so I had better find some wood to touch ?
I don’t know but I’m guessing - in answer to your “why not take the fuel from the main tank” question, maybe it needs the flow/suction from the day tank to work?
Do you use any relevant checklists to conduct regular maintenance and boat safety inspections? Also, is it necessary to store the inspection reports for 6 months?
Personally, no.
I know what needs to be checked and don’t need a check list to remind me to do so. Any more than I need a check list to remind me to check the oil, coolant, tyre pressures, lights etc on my car.
I keep the BSS certificates permanently and have many years worth.
