morgandlm
My Sadler 26 has the original Bukh DV10 which has been well looked after and had never let me down. Last Sunday I enjoyed a weekend cruise which involved several uses of the engine without any problem. For the return to the marina I had started the engine and motored for about 15 minutes to get to my pontoon berth. All the foregoing was perfectly normal. However, about 50 metres short of my berth the engine simply slowed and stopped as if run out of fuel. The tank was half full and the supply valve open.
I subsequently checked the filters and changed the secondary, spin on fuel filter although the one in use was only a few months old. No evidence of dirt or water was found. I bled the system and eventually got the engine to start but it was very reluctant – firing but not sustaining itself. It eventually started but only runs very slowly and will not speed up when throttled up. My feeling is that there is a problem in the injector pump / governor system but do not know enough about how this works. This latter would perhaps explain the not speeding up but I do not see how it would explain the coming to a stop when running perfectly.
I would be most grateful for any suggestions or possible diagnosis.
By the way I was very luckily able to drift to the end of my finger pontoon, catch a cleat and with some help from the shore, berth the boat. A dry mouth moment!
David Morgan
David Morgan
