noelex
The difference with a rope, or mixed rode is that you don't need a snubber if the rope part of the rode has sufficient elasticity.
Rope rode will be thicker than the correct sized snubber. It also may not be nylon. These factors means the rode will have less elasticity per unit length. Therefore you need a longer section of rope rode before the stretch is adequate.
If the rope section is too short and the stretch is inadequate you need to use a snubber, just like you do with chain. If necessary the snubber is usually attached at the chain where it also serves as a back up in the event of chafe.
