fred b.
New Member
Hello everyone. New to this forum. I just bought a boat with a 40 hp Johnson. It has the VRO ? system. Oil and gas mixed from separate tanks. It is a 1996 model j40el8ds. Plate is damaged so I think so. ser.# G04192197. I am having trouble with idle, and low speed miss. At mid rpm it straightens out and runs fine. Sometime starts fine, other times it starts hard. my mechanic who is so far behind it is 2 months just to look at it. He says just eliminate system and mix gas in tank. If that is issue it will eliminate it. Cheaper and better than figuring it out, and repair or replace cost. Several things can cause this problem. So start there. Has anyone done this. I assume I will have to use an electric fuel pump, but does entire unit have to come off or just plug it off ? Any advise is appreciated.
