Boater Sam
That is still puzzling me too.it seems that part number 128990-77550 is the more recent one. Hopefully they've fixed whatever issue it had. Plus, I'm still puzzled why the
panel would have gone black. Unless activating the relay cause a short somehow.
If it was a short something would have got distressed and hot.
I still think that it is a poor connection somewhere that will not pass the current needed for the solenoid to pull in, it is quite high.
I would carefully check all the connections and cable crimps that are on the back of the starter motor, that is all the positive feeds and similarly all the negative connections, a bad contact or termination on either will cause the voltage to disappear at the panel.
Engine vibration can do odd things to electrical wiring causing intermittent connections .
An interesting fault, but not for you !
