clonlara
Hi guys. My engine overheated recently due to a water pump belt breaking. When I checked the impellor it too had disintegrated. I don`t know which happened first.
I replaced both the belt and the impellor and removed the debris from the impellor from the outlet hose to the heat exchanger.
I noticed after motoring for about 40 minutes that I was getting a small amount of steam from the exhaust. I assume both things are connected
How do I ensure that all the debris is removed and how important is it that it is removed. could some have gotten up into the heat exchanger.
My exhaust outlet is under the hull of the boat on the waterline and so it is difficult to see how much water is being pumped out.
Any body got any ideas as to what to do next.
Thanks in advance
Colin
Thanks in advance
Colin
