Ian_Edwards
I started a chain by asking the question:
Will a set of Sealey S1 AK510 bolt cutter cut 10mm 316 SS rigging wire?
This is the link to the original post (not sure I'm putting the link in correctly!)
http://www.ybw.com/forums/showthreaded.p...rue#Post1802493
The consensus was to try it and see ... which is what I’ve done.
If I’ve got the procedure for posting pictures right (1st time), then you should see a series of pictures, starting with the kit, the initial cut, piling the pressure on, when the handles came together, how the blades crossed and the overall effect on the wire.
The answer is NO!
At least the way I tried to do it, the blades seem hard enough to cut the wire strand, but the shears aren’t stiff enough and the cutter effectively rolled on the wire.
Back to the drawing board ... the shears can join all those other use once (because they don’t work) tools in the garage.
The answer is NO!
