Ian_Edwards
I've just bought some bolt cutters, as the almost mandatory safety device, although personally I think a good hack saw with good quality blades or pulling the pins on the chain plates are good options. The bolt cutters say they are good to HRC35, which I take to mean Rockwell C 35. I’ve looked this up on the web and it converts to an ultimate tensile strength (UTS) of 1103MPa. 316 SS has a UTS of 579MPa, so all looks OK, a safety factor of almost x2.
But that’s an annealed value, if the 316 SS is cold worked, like the way the wire is swaged into fitting, it look like the UTS could go as high as 1241MPa, which is above the rating for the cutters.
In addition the cutters work in shear, so is UTS the correct value to be looking at?
Since I’m no expert ... just trying to understand if the bolt cutter will really work when I really need them to. Am I on the right track??? Where do I aim the cutter? Presumably not the rolled swage, but at the wire or at the treaded part of the turn buckle?
Any expert help and guidance out there?
Cheers
Ian
Cheers
Ian
