Plevier
Getting back to brass tacks. My book of words makes reference along the lines of...
The starter battery is subject to 2 conditions of use.
1. Shallow discharge due to starting the engine once or twice a day.
2. No discharge at all.
In practice however the starter battery will very often be charged in parallel with the house battery, which is acceptable as long as the right type of battery is used and some decrease of service life is accepted.
So basically using the Victron charger as the OP has, with 3 isolated outputs - it needs 1 to house and 1 to engine. The last output remains unconnected as bridging not needed on this type of charger.
Batteries sit on the same charge stage until all the batteries are happy then move on to the next stage until it reaches the last state of charge.... lounging about waiting to be used. If the charger is still on when power is used then the Victron will act as a power supply until you really hit it hard, then power is also taken from the batteries.
The last few words make it clear that there could be a reduction in service life of the engine battery. So by that we conclude that using the Victron charger as a multi isolated output charger can be used to charge a high turnover domestic bank and a very rarely used starter bank but the starter bank may have a shorter lifespan.l
Just so. To forestall a possible response, yes it is "may" not "will", depending on the particular circumstances.
