ghostlymoron
I didnt know that thes e functions were adjustable on a simple tiller pilot.
I didn't have a manual as the pilot was inherited with my boat. I'll read it on line now. I wasn't expressing any criticism, merely surprise. Apologies if offence caused.Perhaps you didn't read the manual, then?
None of the other self-contained tillerpilots are any better.
I have a Navico 1600 on my boat. I have no idea how old it is, but it could well be the one for which the original owner paid £204 + VAT back in 1986. It works reliably and dependably and seems unperturbed by weather: I have used it in some pretty manky conditions. Just in case, I have acquired a s/h spare and a brand new old stock 1800.
It seems bizarre that modern manufacturers cannot seal a cable and a pushrod as well as Navico could, 28 years ago. Was chatting to a fellow owner of my model of boat in Bangor a week or two back, and he also reported (a) that his Raymarine tillerpilot kept failing and (b) that Raymarine had said that it was his own fault for using it at sea, for which it was not designed. "Harbour use only", apparently.
If anyone has a dead modern tillerpilot, it might make an interesting PBO article to pull it to bits and look at ways of beefing up the sealing. It would stuff the warranty of a new one, of course, but might be worth doing the day the warranty expires.
does it really say for harbour use only..... surely not
That's what my fellow Victorian said Raymarine told him, so it's hear2say.
From the ST2000+ manual it talks about passage making, sea state, keeping a watch out for ships travelling at 24 knots, following a route of waypoints, making plots of position hourly in open water etc. So I would say that your hearsay is just that. And why would you want an autopilot for harbour use anyway? It's the one place you don't want to use it.
does raise the question of while they don't make the damn things waterproof.
Raymarine's reported response was, as I wrote, that they weren't intended for use at sea.
I still very much doubt that they said that. It sounds like Chinese whispers to me.
Got the same response. Also told I shouldn't stow it in a damp cockpit locker. Asked if it'd be OK by the fireplace in my living room. No response.I can sympathise. Mine (ST2000) stopped 2 months out of warranty. The estimate to repair was more than the original cost. The Raymarine distributor told me I shouldn't have let it get wet.
A marine machine intended to work in the cockpit......!!!
My son is a journalist and he says if you can't attribute a statement to a verified source, you have to assume it's not true.It seems bizarre that modern manufacturers cannot seal a cable and a pushrod as well as Navico could, 20+ years ago. Was chatting to a fellow owner of my model of boat in Bangor a week or two back, and he also reported (a) that his Raymarine tillerpilot kept failing and (b) that Raymarine had said that it was his own fault for using it at sea, for which it was not designed. "Harbour use only", apparently.
I started this trip with two tiller pilots
an ST 2000 that came with the bioat that was amazing
at night it was better on the helm than any human
but it rained and it stopped - now all it does is beep like a sad seagull chick
the other was the st1000
less good but I have been using it since I started KTL so it had a seven year bashing
It has got a bit wet but a few minutes under the fan heater and it starts again
not this time though
after the journey between Orkney and Eirbol when it got wet a few times it has also expired
the fan heater treatment produces no cure
does anyone have an old but unwanted one they are willing to swap for ktl DVds
yours
Ron Hopeful
PS - here is the story of the journey
http://www.keepturningleft.co.uk/sailing-around-britain/best-of-times-and/
