kcrane
I got a little 4 stroke Honda o/b with the new boat. I don't think it is very old (I have the manual, toolkit etc). It has a twist grip throttle, not the one with a lever on the o/b body, but no F/R gears.
It starts OK'ish - 3 or 4 pulls, then idles solidly enough. At gentle revs it works fine, pushing a 285 RIB at walking pace. It is a bit noisy (air cooled I hope, cos no tell-tail) but it phuts phuts up and down the fairway OK. I can blip the throttle to kick in the centrifugal clutch to steer and it doesn't die.
But, when I open the throttle more than a small amount it struggles, and would die if I didn't back off, as though either fuel starved or maybe too rich.
I've checked the plug (but haven't replaced it) it looks in good nick, no soot for example.
I've had the carb off (thanks to help from VolvoPaul, who I tried to encourage to become HondaPaul) and cleaned it, It all seemed fine, no blockages or sludge. I refilled with fresh fuel and it restarted fine, so the two pieces I had left over weren't important.
Only kidding about left over bits... but I still have the same problem.
I've wound the mixture screw in and out 1/2 a turn in both directions, with no real difference.
Does anyone know how many turns out from fully screwed in the mixture screw should be?
Also am I expecting too much - is it only capable of going phut phut at walking speed?
Largely this is just interest in fixing it, seems a shame not to have it right. I'll get a somewhat larger replacement when I decide what to get!
