You only have 2 bearing points - the gearbox coupling and the P bracket and the maximum distance between bearings for a 1" shaft is 1.5m. That looks well over a metre. You don't say what shaft seal you have and whether it provides any intermediate support. I know it has been there from new, but that does not mean it is right. When small diesels came in builders stuck to small shafts for a while until they found the problems. While you might accept 22mm or 7/8" for a 1GM it is crazy for 2GM and does not follow Yanmar recommendations. yes, you will have to change the shaft seal and cutless but they are pennies compared with what you are pending on a new prop, coupling and shaft. Check the ID of the stern tube, should be 30mm minimum for 25mm shaft but is likely to be more than that.but then wont the stern gland, coupler and P-bracket/cutlass, hole in hull need resizing too then?
the shaft is quite short, it fits inside the cockpit footwell
Is it the photo, or is the shaft out of line with the gear box drive?
