superheat6k
Providing the single phase is simply one phase (any doesn't matter which) to neutral then the balance of the RCD is satisfied. An RCD works when the current does not balance, e.g. current in both neutral and the phase must balance, so if they do not the current flow must be to somewhere else, i.e. via the protective earth, which will trip the RCD.Can't you actually get 230V only from one phase+neutral, when using one of those red 3ph sockets?
Phase+earth would trip the RCD, afaik.
