1inch Npt thread to bsp connector
Siftasam
23 Jul 2016
Good morning.
Can anyone advise where to obtain 1inch npt male to 1inch bsp convertor. ?
Have refitted the engne intake with a bronze Perko skinfitting.
However being USA profuct the take off is NPT 1inch female which I need to convert to BSP to connect to our existiing Perkins set up.
Have searched i/net but only found brass so not much good for our salt water sailing. Perko do supply a bronze hosetail so if worst comes to worst will have to put in plastic.
Much appreciate any help.
All I can suggest
All I can suggest is A.S.A.P. Ltd.
Thanks Poignard but asap do not have one. Surprising as they supplied the valve.
. . . or your local hydraulics supplier.
A bit worried about the metal of hydraulic fittings…?
Or buy one of each and get a specialist to weld them together.
That sounds a good option We have. Inquired about having a fitting made but hugely expensive!!”
Thanks PCUK- did exactly as you suggested -Mr Stainless sourced on from one of his suppliers. Has worked fine- fingers crossed no problems down the line..
