slawosz
Hi,
my water pump is leaking through drip hole. I found this service kit - Yanmar 1GM10 Raw water pump impeller & service kits - I wonder if anyone has experience with parts4engine, as those are non Yanmar original and I wonder about quality.
Now, I took a look into exploding diagram of the pump it seems very easy. My question is, do I need to lubricate anything other than impellor itself?
I also have old pump that seems to be overhauled - I understand I can check it simply by installing it and seeing if water is flowing and its not leaking?
Regarding shaft, how do I check if its due to replacement?
Thanks!
Thanks!
