Refueler
For descaling equipment use a 10% solution. Sulphamic acid is safe for steel, iron, glass and wood equipment, and may be used with caution on copper, aluminium, and galvanized metal surfaces. Clean in a soak tank or by circulation. For surfaces, apply to surface using a cloth or brush and allow to work for a few minutes. Agitate with brush if necessary and rinse thoroughly with clean water.
That is from the link post #20 ...
The mention not to use on such metals is in the higher concentrates in the next paragraph of the sheet ... it also gives clear indication of a neutralizer ... if you are so worried about using it.
As I say it was a commonly used method before ... but we always ran the motor after in a bin of clean fresh water ...
