petem
That's what I did, had the unit installed in the water then had the thru hull done at the next lift.Thanks Pete.
I've engaged with the firm in Cartagena regarding A/C. They supply the units and everything needed to install it including the seawater pump (with exception of the 2 required thru hull fittings) but do not fit - so quite fancying having a go at installing myself.
They have suggested that I would only need 1 12000BTU unit for the Targa 37 - and there is room to install it under the seating in the main saloon running with flow into the saloon - and ducting to 2 further outlets (1 in the master cabin and a second in the aft cabin).
I have the size of the units - and will need to measure the available space in the Targa when the purchase is complete.
Their advice is to get the boatyard to install the thru hull fittings (just in case there is any leakage afterwards!). Considering buying the unit and installation kit and installing it over the winter months - then having the thru hull fittings done around March (when I'll probably need it lifted out for anti-fouling) - then connect it all up to keep cool in the summer months.
I realise a plan for AC is only a plan - but at least now I have one.
My jury is still out on need for generator. Seems costly option for keeping ice cubes intact.
Note that some people advise against the pump output being under water. Speak to the manufacturer for guidance.
Also, don't forget to run a hose from the condensation tray to the shower sump. Don't let it drain into the bilges.
