CLB
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/273488770875
You can thank me later
Sounds good to me ��
I doubt 200hp will be enough, suspect it will just climb the hump and push a huge wall of water at about 12knts, that is not a small boat.
Its a planing hull so it will do up to about 7/8knts in displacement mode with minimal hp of say 100hp which would be perfect with some margin to push a tide. But it cannot operate at speeds of 8-15knts until it has climbed over the hump and is fully planing and that will require 300hp. There are plenty of example of similar boats that are under powered with about 200hp and will not plane with more than two people on board, full fuel etc... e.g Sealine S28 with a KAD42 (230hp diesel). 200hp will not be enough.
Plus a diesel engine has more torque - I suppose if he changed the prop to a much finer one (effectively running in a lower gear) he would lose top speed, but generate more power to get on to the plane. It will be an interesting experiment.
The engine is 250hp ��
yes but where does it develop it's torque. If it develops it's torque outside of the displacement to planing transition band you may never see the motor delivering all those ponies. If it helps think of a car in top gear trying to take off uphill. If you then underprop it to get the torque (i.e. 2nd gear) you will also not see all those ponies put to use plus not go very fast. i.e. on the plane maybe but not much more in it.
'will likely be river cruises up and down the Medway as far as Stangate which is a great little overnight creek just before the Medway reaches the Thames estuary and longer cruises in the Thames estuary and up to the far reaches of the Thames its self'
Speed limits according to Google:
The speed limit above Wandsworth Bridge is 8 knots. Between Wandsworth Bridge and Margaretness Point (roughly three miles east of the Thames Barrier), it is 12 knots.
why does the boat need 300 Hp ?
OKi my thought is this. 50hp will move the boat right so 250hp should move it pretty well. So if I have a pod/bracket designed that would accommodate say a single 350 I can start with the 250hp and if the need suits upgrade to something bigger or more efficient but at least I have a starting point now ?
The engine is 250hp ?
