cygnusv
I did put this enquiry on 'Reader to Reader' but the first response I got was that I should repost here, as this is where I will find the right advice.
As you'll see from the pic's, the exhaust flange studs have all broken and the exhaust elbow fell off. My intention was to get hold of a service exchange unit but unfortunately (so far) this has not been possible. The price quoted for a complete rebuild was off the chart. Looking at the damage, I see an engineering job - re-drilling, tapping and new studs. I'd like views on this if possible.
Alternatively, if one is available, I would consider a fair priced exchange if anyone has old stock. The engine and turbo numbers are listed below.
Engine numbers
Serial 066172
Type 150
Numbers from the turbo plate
Header title 'Hoeset' or 'Holset' - 3rd character not clear
S/N 442799
Part number 55325/1
Engine num (looks like) 3L092.24
There appears to have been a spacer plate (about 5mm thick) seperating the exhaust flange from the elbow, I've not tried to seperate it from the elbow yet. Also, when I removed the elbow there as a rotten clamp there too. I need to identify a replacement for this.
So then, any ideas?
Apologies again for the apparent double post.
Many thanks, Stu
Engine numbers
Serial 066172
Type 150
S/N 442799
Part number 55325/1
So then, any ideas?
Many thanks, Stu
