vyv_cox
Apologies if I've misread the comments above. I appreciate that CD spec oil is designed with TBN of around 4, but from what I can understand, TBN is the ability to neutralise the acid byproducts. Could someone explain why a high TBN would harm a low power Marine engine ( say Bukh 20).
Chris
Optimum wear rate is achieved when the oil is neutral. Running an engine with either acidic or basic chemistry will lead to higher wear rates. We avoid high acidity by regular oil changes. We can't avoid high alkalinity if we use oils with high TBN. There is a good deal of evidence that high TBN will lead to bore wear, perhaps cam and follower wear in the medium term. This would be bore polishing, not glazing, giving smooth, reflective surfaces that cannot transfer oil beneath the rings.
