14mm square switch panel stickers?
Any idea where i can get custom made 14mm square switch panel stickers from?
Also, do i wire it as per sketch (circuit breaker panel)?
Cannot help with the labels but yes wire it as in your diagram.
Pity it does not incorporate a negative busbar
I bought a Blue Sea fusebox for Ariam; they had a version with negative busbar and one without. I'm actually glad I chose the latter - by mounting a separate busbar along the top of the wiring bay I was able to have less cluttered wiring with half the number of wires trying to get to the same place.
Admittedly I have more wiring than the OP presumably does with a little six-switch panel.
That's why I used a separate switch panel for each room. One massive one was a mess and complicated.
