13A sockets onboard. Sanity check pls.
I am still learning about double pole and single pole, Are there good technical reasons to go for double pole pls ?
Double pole switching is required on a non-polarised system and that includes , perhaps more importantly, 2 pole circuit breakers or RCBOs
Leaving aside the double gang/double pole issue, one thing to beware of with USB chargers is that, if they aren't boasting about the power output, it probably isn't very high, so may struggle with a hungry tablet. If that particular socket does give a power output, I missed it. Even when they do give it, it's often the combined output, so an output of 2A will give 2A with only one item plugged in, but only 1A each if you plug two in.
If you boat is set up as a normal UK mains installation with a live and neutral wiring. ( with the neutral connected to the earth line at the supply transformer. A single pole switch of OK as long as the switch is in the live side.
If your setup is a balanced system with no line earth connection generally a double switch is better as it cuts off both line conductors as either or both could be above earth potential so could give you an electrical shock
Tks, VicS. I guess I need to take the MCBs out of the consumer unit and check their spec and that of the unit itself ?
I have a good idea that the previous owner was pretty clued up on electrics.
Stemar
And perhaps a set of purpose designed USB charging sockets rather than ones piggy backed onto a 13A socket ?
For USB charging I fitted a USB socket in the 12Volt DC system, replacing the cigar lighter type socket. Its then possible to charge the phone or tablet without needing shore power .
My boat has standard domestic sockets for the battery charger and immersion heater which are in the lazarette.
Bear in mind , though, a tablet/phone etc will likely only draw 0.5A or less from a usb power source which isn't clever enough to set the data pins voltage so the device will pull more. My samsung tablet will only draw about 0.450mA from anything onboard but a samsung charger.
For 5v a quick test shows this buck converter to hold the voltage at 5v or slightly above up to ...... bish, can't remember! , think it was up near 2A @ 5v. More testing to be done :)
jielaite 5v - Google Search
Double pole isolates supply completely when off. Useful perhaps at plug socket perhaps if fed from supply when you are not actually sure that the positive BX+ is actually correctly connected to that ,or is floating voltage system, thus the supposed negative may still have voltage to earth on it at the outlet. Unless you are in the habit of sticking fingers or metal object in the negative socket or wires connected to it, then it wont make any real difference.
More useful and indeed EU mandatory in the consumer unit when you switch off to isolate the rest system when changing wiring/sockets etc further down the line
Not sure why, you don't need dual pole circuit breakers. You do need a dual pole RCD, isolator switch or RCBO.
Stemar
You'll need USB charging when away from shore power at some point, so may as well forget about the ones in the 240v outlets.
Our boat is equipped with 4 MCBs in the incoming feed, (sockets for, sockets aft, battery charger, water heater) ... and a convenient 4 way "lightswitch" to allow invidual circuits to be turned on and off.
Apparently the ideal place to put this is in the wet shower ... our surveyor didn't object, so I can only assume it is correct way to do it ....
Hopefully also an RCD
yes, when you go foreign like us and find the marina is wired with live and neutral swopped. Single pole live switch and your appliance when switched off is still live!
Mine isnt but I do know some that are! One of them taught her child how to dry tea towels in a micro wave. It was interesting when the child and its friends decided to dry a hamster!
In many European contries double pole switching is universal and no-one has to care whether live and neutral are swapped. Appliance plugs can often be inserted correctly or reversed - noone cares.
Cautious UK caravanners carry and use a polartity checker {under £10 from Toolstation etc) because UK caravans typically use single pole sockets and caravan sites sometimes offer reversed polarity -as a no cost option!
We do exactly that on the boat and have a live/neutral reverser made up, so we have stayed with single pole.
In many countries the mains supplied at marinas is 127V 3-phase, with Live and Neutral in 220V 16A or 32A sockets - ones we normally plug our shore-power cables into - being wired between two phases. Thus there is 127V between neutral and earth as well as between live and earth. So it might well be better to have both live and neutral switched in the 13A socket, and as the DP sockets don't seem any pricier or harder to come by than single-pole ones one might as well use them imho. (I still unplug before tinkering inside an appliance 'tho!)
