VicS
The "discharge" current only appears when my alternators are running. For example, if I remove the bulbs from the alternator warning light, such that the alternator field coil doesn't excite, no discharge.
I'm pretty confident that what I see is due to the relative location of the 0v reference. On my setup, it's on the battery side, and in yours, it's on the bus bar.
If the OPs setup is as I originally described, then he may be seeing the same issue as I am (except in his case, he can move the solar onto the bus bar side to fix the problem)
And if it's not, then what I've said is irrelevant and can be ignored.
If his solar panel negative is connected directly to the battery negative (or the battery end of the shunt) the current will bypass the shunt and it will not register as either a charge current nor as a discharge current!
I'm not sure why you are concerned about the "0 volt reference" The current flowing through the shunt will produce a potential difference across the shunt. Its magnitude will be proportional to the current and its polarity will be determined by the direction of the current flow. A charge current will make the battery end of the shunt positive with respect to the other end whereas a discharge (or load) current will make the battery end negative wrt the other end.
That means that if you take the battery end as 0v a charge current will make the other end slightly negative while a load current will make the other end slightly positive.
Thinking about your system. Is it possible that your alternator has an insulated negative ? If so it would enable the two batteries to have their negative terminals connected together and the engine starter negative ( and cylinder block possibly) connected to them and for the alternator negative to be connected via the shunt. That way the starting current would bypass the shunt while the alternator current would pass through the shunt and be registered by the monitor. If that is the case there is no reason why it should not be wired so that a charge current is displayed as a charge current while a load current ( lights etc) when the engine is not running shows as a discharge.
As it is how does a load ( lights and whatever else you have) display when the engine is not running? As a charge or as a discharge?
