andythilo
Anyone know where I can get either a 1/2" BSF temperature sender or threaded adaptor for my BMC Newage Navigator?
it wont be 1/2" BSF, it will be BSP, and the OD of the pipe isnt where you measure it. 1/8" BSP is about 3/8" OD, 1/4"BSP is about 1/2" ODAnyone know where I can get either a 1/2" BSF temperature sender or threaded adaptor for my BMC Newage Navigator?
Assuming that the engine is based on an A or B series BMC engine, and I am pretty certain it will be, I am certain, from first hand knowledge, that the gauge fittings are BSPI took it to an old engineering workshop and thats what they told me. He even had a 1/2" BSF socket that it screwed into??
The engine bolts and studs were UNF and UNC on the later B series, see here http://books.google.co.uk/books?id=...epage&q=BMC B series engine unf studs&f=falseAll these fellas are too young to remember what BMC used in the dark ages.
Your engine is a derivative of the BMC B series engine and quite possibly has BSF threads I would suggest you try Halford's as they have a selection on the shelf and if not try various scrappies. You are looking for Morris or Austin car engines of the 60s or 70s unfortunately a lot of these cars had a spirit bulb sender so you might have a problem finding one.
You may have to get an adaptor made to use with a modern one however you will have to match the resistance values of the old one or get a new sender and gauge.
Try hereAnyone know where I can get either a 1/2" BSF temperature sender or threaded adaptor for my BMC Newage Navigator?
BTW why are there BSP fittings on a japanese Yanmar?!
Race and rally type car shops are quite good, I found Merlin Motorsports at Castle Combe very helpful.
Alternatively, you could get a brass plumbing fitting and re-tap it metric.
