AntarcticPilot
I was interested to see reference to wire-wrapping. When I was involved in prototype electronics in the 1980s, my colleague who built the stuff use wire-wrap almost exclusively to build the circuit boards (no one-off PCBs in those days; it was Veroboard and wire interconnections). He swore blind that the electrical connectivity was better than a soldered joint, and the connections were very quick and easy to do with the right tool. Our circuit boards were used in an aircraft (Twin Otter), and subject to a lot of vibration and shock loads. We never had a failure, and these were pure wire-wrap with no extra solder.
We used soldered joints elsewhere, especially to connectors, and I've soldered a very large number of D-type connectors, but the circuit boards were built using wire-wrapping. It has obvious advantages when you're changing things in a prototype, but they do work very well.
That said, it's difficult to see how wire-wrap techniques would be useful on a boat, unless you were wiring a panel. It also doesn't work with stranded wire.
