MagicalArmchair
I have never completed a gas compression fitting in my life - however, this being PBO, I do want to do it myself so if anything fails at sea, I will have the knowledge to put it right (not to mention having the satisfaction of doing it myself).
I am getting a bubble tester to go next to the gas locker (alas, no space in it), to test for leaks. I have a gas testing wand arriving too just in case I need to track down any leaks. Additionally I will use some deionised water and shampoo on each joint to test to see whether they leak. Each separate copper run will have a stop cock to isolate it (a kind skipper on here suggested that).
Questions:
- I am using 8mm copper pipe, and the fittings are 5/16s - the total difference being 0.06mm between the two and I figure the tolerances of the pipe are such that that won't matter a bosuns parrot.
- I am going to use gas PTFE tape on the (copper) olive, as a secondary seal, and I am going to hand tighten plus half a turn. (I will do some 'test' joints in my garage, take them apart, and make sure the olive doesn't move to ensure they are tight.).
Questions:
- Hand tight plus half a turn of 5/16ths the right amount?
- Now I know I don't strictly need the PTFE on the olive - however, it won't adversely affect the joint will it?
- Seems likes lots of threads everywhere with this sort of install - I'm concerned they might vibrate apart - I note everywhere I have read they say do not put anything on the threads of the compression joints - fair?
- I am using a standard camping gaz regulator to two appliances - cooker and heater - is that okay? (a bit like this one: http://www.gooutdoors.co.uk/camping...ghiSl32RqNKn_tTzCKdn0aAqRO8P8HAQ&gclsrc=aw.ds)
- Can anyone suggest a good video/web guide/blog/book on the subject?
