bammylovechops
Hello,
I was fed up with my water tank gauge never being accurate so I decided to try to fix it. I thought it would just be a simple case of replacing the tank sender unit. I cut the new sender probe to length
( thanks to Nick at Seabridge), installed in the tank and it is still not reading accurately, I also removed the resistor in the gauge that shows the water level in the tank as per the recommendation in the instructions that came with the probe.
The problem is I'm not actually any better off in getting a true ish guide to how much water I've got.
Other than now having to replace the gauge in the dashboard, and I still don't know if that is the fault!
Any thoughts appreciated.
The boat is a Sealine F34 2006.
Mark
Mark
