nondikass
I have had to replace the control panel on my Sidepower bowthruster three times in 5 years. It is a touch panel type and the problem seems to stem from the membrane surface not being up to the job. The current Vetus panel seems to be a better option, as it has done away with the membrane and uses left/right rocker switches.
My Sidepower is about 10 years old, the old 3 wire type, but I have managed to intstall the necessary 4 wire cable.
I cannot get the Vetus panel to complete the power-up sequence.
I have found out that Sidepower utilises negative switching, whereas Vetus incorporates positive switching.
Are the 2 systems mutually incompatable, or has anyone managed to marry the two together?
Would apreciate wiring advice, or ideas on other suitable controllers /forums/images/graemlins/confused.gif
