4.5kg Calor Gas Problem !
normskib
27 Sep 2010
For over a week now l have been trying to replace my 4.5kg Calor Gas bottles tried just about everywhere known to man ! And the bad news for me is that I am now being told by main suppliers that there will not be any new supplies of the 4.5 size because it’s no longer viable to fill them ! Which is all very well but The 4.5 bottles fit into a specifically built compartment on my boat anything larger simply will not fit. Now what? answers please on a piece of paper ?
thamesS23
30 Jan 2006
hertfordshire
www.spotonprint.net
are these what are also known as Euro size gas canisters - if so we did have the same problem getting refills for our S23 sealine (they fit into a moulded section, so can't use any other type
Northern Star
25 Dec 2020
Have you tried Nauticalia at Shepperton as they had a good selection of sizes a few weeks ago when we stopped for a 13kg one?
normskib
27 Sep 2010
Yes I did try Nauticalia last Thursday! ! The Guy that operates the ferry could not have been more helpful ! We even went through the empty’s to see if one had been put in the wrong place !! but alas no luck ☹️ But thank you for your suggestion
oldgit
6 Nov 2001
Medway
4.5 K.................Join the gang :(............................There have been none around anywhere for at least six months or more ...............................and no sign of it ending anytime soon.
Momac
7 Feb 2008
UK
I had a s23 and it took Campingaz 907 cylinders as does my F33.
I bought 907 refills as recently as June and August this year.
There can be shortages of some cylinders due to extra demand during Covid.
st599
9 Jan 2006
Have you looked at refilling from a larger bottle, there seems to be lots of kits about although i confess
I dont have any idea if they work or not.
It's not legal to refill such a gas cylinder and can be quite dangerous if you overfill it or allow it to become too hot.
You can buy refillable cylinders designed to be attached to an LPG pump in a petrol station. Initially pricey, but cheaper refills (CampingGaz 907 is about £30, about £5 at an LPG pump).
There's a steel CampingGaz sized bottle at Gaslow or a few do 5kg bottles that might fit.
PilotWolf
19 Apr 2005
Long Beach. CA.
Wasn’t there a long thread about this a little while
back?
I was on FB for first time in a good few days and see home town area of Lewes is suffering fuel shortages…
W.
plumbob
18 Oct 2009
Bucks
Seems to be no shortage of propane of the same size. If I can't get butane, will fit new regulators and use propane. I have 2 bottles, so that helps. I don't think they allow you to swop types so if you go this route it means a new agreement.
st599
9 Jan 2006
harvey38
27 May 2008
Get small Safefill cylinder, I use a 7.5 kg one, it was running low so took it to the local LPG man and put in just over 4kg, it cost me £3.90, unbelievable considering an exchange 13kg Calor was around £40✌
oldgit
6 Nov 2001
Medway
one of these ?
Safefill Medium 7.5kg LPG Refillable Gas Cylinder
st599
9 Jan 2006
The op has the same issue as many boats - a fixed size gas locker - very few of these sites are giving the physical dimensions of the bottle.
I'm seriously contemplating a Gaslow CampingGaz replacement, but would want to double check it fitted as the regulator clearance is small.
