Winch service grease and or oil
MJWB
24 May 2019
Yorkshire coast
For winch servicing I've heard mixed views on what to use for lubricating the pawls and springs. Some say grease is fine. Some say no grease on pawls, use oil. Any thoughts? And if so what oil?
Many thanks. :)
Stemar
12 Sep 2001
It seems fairly unlikely that grease could prevent pawls and springs from operating correctly
You didn't see the grease on my winches the first time I serviced them. Plenty of grease, but it had set hard, so the ratchets barely worked. I cleaned everything up and lubricated them with 3 in 1 oil. No more problems.
jac
10 Sep 2001
Home Berkshire, Boat Hamble
No grease on the springs a touch of any light oil instead. Gears should have a VERY LIGHT smear of grease. you use so little it barely shows. I bought Lewmar winch grease - it's more expensive than cheaper ones but it's one area when scrimping to save £10 over 5 years seems silly.
Pawls shouldn't ever be greased - it can make them less likely to spring into position so some light oil ( 3 in 1 for me)
Lewmar have an official you tube guide that walks through it
- See how little he applies.
penfold
25 Aug 2003
On the Clyde
Harken charge a fortune for a thimbleful of some thin oil to go on ratchet pawls; I use Muc-Off wet chain oil, as it does the same job for perhaps a tenth of the price and being intended to resist wash out seems appropriate. Bearings can be greased with near on any grease as long as it's fresh.
Close hauled
5 Mar 2003
I agreee - grease in gears and oil on pawls. Maybe I’m a sucker but I’ve always used Lemar or Harken products which are expensive but as you only use a tiny bit last for years and years and years. Only problem is remembering where you’ve put them.
V1701
1 Oct 2009
South Coast UK
If it was me I'd use ACF50 because I have it in stock, very light, about the best penetrant I've ever come across, used as rust protection on aircraft originally, a lot of bikers now use it. I also "paint" boat engines with it. You don't want to get it on brake discs it's as slippy as...
Edit - I would add that if you do it regularly I don't think you need get hung up on what you use, i.e. no real need to buy expensive Harken snake oil...
johnalison
14 Feb 2007
Essex
We had a demo from a Lewmar agent, along with a take-apart and reassemble race that I nearly won. We were give little freebie kits that included a brush to apply the grease with, and that is what I have used since. As said, you use very little. It is so little bother to use light oil on the pawls that I can’t see why anyone would want to pass on this. I dare say that pawl failure is rare but it could be very unpleasant if not disastrous.
graham
I have had to strip down winches where the pawls were jammed open by old hardened grease so its a drop or two of light machine oil for those.
Problem is you are unaware of the problem until the last pawl doesnt engage and the handle wizzes around and breaks bones in your wrist or hand.
Biggles Wader
3 Mar 2013
London
I have a little tube of oil, I think it is sewing machine oil, which I use to splash a tiny amount on the moving parts every few months. Otherwise I leave them well alone. Has worked for me so far.
Beelzebub
7 Jul 2008
We were racing in Cork week a few years ago when the pawls in one of our sheet winches jammed open, causing the winch to backspin under load.
Not having time to perform a full service before rounding the next mark, we whipped off the drum and poured whisky onto the offending parts. Although it was a sad misuse of whisky, the winch worked OK for the rest of the race. (y)
PabloPicasso
12 Feb 2010
I use silicone spray on the pawls
I have a toothpaste sized tube of harken winch grease. Bought 17years ago and still plenty left.
I'm not sure why I'd consider using a different lubricant given, as others have said, we use such a small amount.
MJWB
24 May 2019
Yorkshire coast
Okay thanks all. Opened mine up and judging by the color it appeared they had been greased with Blakes seacock grease. Green stuff. All done now with light amount of marine trailer grease and 3 in 1 on the pawls. Thanks all for advice and anecdotes
KevinV
12 Oct 2021
I did mine for the first time (on new to me boat) - they appeared to been greased with bitumen 🙄
