Captlen1
Trying to figure out where should zincs be used in bonding system. Thu ground plates or thru shaft? The boat I am Restoring has a ground strap attached to stern bearing housing then to zinc. Well with a bearing made of rubber it cant be grounded to the shaft and with gear oil in gear box how can the shaft get the ground. Should it be attached to grounding electronics plate?
