alexhibbert
Active Member
Hi all,
I know anodes can be quite a pandora's box, but I had a couple of specific questions for those who are very experienced with using anodes on seawater boats.
1. Is there a rule of thumb regarding proximity? I know the action is via electrical potential difference not a 'barrier' defence - but for instance would a hull anode, mounted forward on the hull, but then sent through the hull and internally connected via a cable to the stern drive, still protect the stern drive? Or does the physical anode need to be within a few inches of what it's protecting?
2. If it's necessary to have interior fixtures and fittings that contain unlike metals, so there's a risk of galvanic corrosion, what's the best way to protect using anodes? Can you simply clamp on small anodes near the at risk areas? Or if a large structure, connect a larger anode and expect this to act to protect all the various interfaces between, for example, galv steel and 304 A2 stainless?
(I've seen the debates on this about how the theory that any mixing of metals quickly ending in rusty tears is often untrue in practice, so long as there's no standing water or a high ratio of one metal to the other)
Thanks.
Thanks.
