schmidp
Hello everyone,
I need some help calculating the required zinc anode weight for my steel boat, because the coating from the last owner came off when washing it with a high pressure washer, I am going to sandblast the hull on the weekend and repaint it from bare metal.
Since I am already stripping it down, I want to ensure I have the right amount zinc anodes as now would be the best time to weld in new bolts.
It's 9.2 meters long, 2.7 meters wide and 1.25 meters draught.
The waterline is about 8 meters long.
I found the following link to calculate the amount of anodes:
Anode Weight Calculation Formula
8m = 26.2467feet
2.7m = 8,85827 feet
1.25m = 4,10105 feet
Anode Weight (lbs) = [(Wetted Surface Area) x (Current Density) x (Immersion)]
[(Energy Content) x (1000 mA/Amp)]
26.25 * (8.86 + 4.1) * 2ma * 8766 hours / (368 * 1000) = 16.21 lbs
16.21 lbs = 7.35kg zinc anodes.
Does that make sense? Or does this seem off?
Currently the boat has 8 anodes at the hull and 4 round ones at the rudder.
Most of the anodes are more than half gone, so I think it is not over-zinced.
8m = 26.2467feet
2.7m = 8,85827 feet
