yet another solar panel query(yawn)
born2sail61
18 Oct 2013
Harwich
I've been given a 15w panel. I read somewhere that with a panel this size a charge controller isn't essential. Is this correct? Can I connect direct to battery?Don't want to risk cooking the 85ah battery. Apologies if this has been asked previously and thanks
JumbleDuck
8 Aug 2013
SW Scotland
I think the general guideline is that you can get away without a regulator if the solar panel rating in W is less than 1/10 of the battery capacity in Ah. You can get a perfectly respectable regulator on eBay for a fiver, delivered ...
JumbleDuck
8 Aug 2013
SW Scotland
Battery and panel connections I get but what are the two connections that look like a lamp?
It will be the "load" connection, but what that does depends on the device. Sometimes it's a place to dump solar power if the battery is charged, sometimes it's a power supply which cuts off when the battery gets flat, sometimes it switches a light on when the sun goes in. See
http://www.sunshinesolar.co.uk/khxc/gbu0-display/faq.html#16
In all cases you can safely ignore it if you don't need what it does.
GHA
26 Jun 2013
Hopefully somewhere warm
It's possible to fry a bank even with a small panel
