noelex
You can of course use any formulae you want to estimate how much chain to deploy, but if you want to calculate your scope you need to use the correct definition for scope.i.e. the first mark includes the height from the bow to the waterline.
This is:
Scope = The amount of chain deployed / (The depth of water where the anchor is dropped + The bow roller height, or the height where the snubber is attached)
Some also incorporate the rise of water due to the tide. This will give you a figure for the minimum scope you will experience at high tide.
Displacing just the first mark to "include the height from the bow to the waterline" or using the "metres of chain in the water" will not result in correct scope calculation.
