supermalc
Despite the plate being missing, I'm now fairly confident from looking at photos, and speaking to engineers my engine is a YSM.
I've changed the engine oil, and removed the 'filter' for cleaning. The filter is fitted onto the bottom at the front with a triangular plate, and has a T handle on the outside. I got the impression this was a paddle in a tube with holes, however on removal I found several thin discs on the inside, that revolve with fixed ones to scrape the sludge off.
I did not realise the position mattered, and had to twist it to remove it. It fits in a round hole, but has an extended piece with a hole that lines up with one in the engine block. The trouble is there are 2 holes, and I need to know I have the correct one. With the flange vertical, the hole lines up with one with a visible channel in the block, which I suspect goes to the oil pump.
Has anyone changed their oil, and removed the filter for cleaning, and knows which way it is fitted.
I have also discovered the oil light switch and water temp sender, or warning switch have wires that lead nowhere. Why do people do such bodges, and how do so many get away with it for so long?
Appreciate any help.
Malc.
Malc.
