cindersailor
I have a Yanmar yse 12 which has been almost completely reconditioned by the previous owner (piston, rings, main bearing, head etc.) however the cylinder liner was not renewed and the engine burns oil, worse when the crankcase oil level is higher. This makes me suspect that it proved impossible to get it out (why replace the piston and not the liner at the same time?). Does anyone have experience of replacing the liner? Access to the head is fairly good and it should be possible to get a puller attached, however engineers I have spoken to cannot guarentee that it will not be an engine out job which is simply not worth it for the age of engine.
