Spyro
Looking for suggestions
My engine starts and runs fine it will run for hours with no sign of an oil leak however when the engine is stopped and the boat is under sail and healed to starboard It starts to leak oil, (no leak if healed to port) just a few drips but enough to make a mess it appears on the bottom of the rocker cover I think it may just be coming from the rocker cover gasket but it must be at the back where I can't see it coming out. First question is why does it only leak when not running and healed to starboard and second is it only one bolt in the centre of the rocker cover holding it on. Third is there any difficulties removing the rocker cover such as the decompression lever mechanism under the cover.
Any suggestions appreciated!
(the Ysb8 has a horizontal cylinder)
