garymalmgren
As mentioned in another post you need three hands to crack/ hold decompression lever/ release decompression lever on a yanmar YS engine.
There is a way out though,
You need a lanyard tied to the lever,
This led astern, through a block and back forward to a reachable position,
There it is held in a quick release cleat.
For a block I used a plastic ring and for a cleat i used a piece of plastic pipe.
To use, you pull the lanyard and cleat it off.
Crank the engine and flick the lanyard out of the cleat.
Timing is important and a bit of practice will help.
Photo 1 the lanyard on the leaver, slack.
Photo 2 the turning ring astern
Photo 3 the cleat.
Photo 4 the lever engaged.
Photo 5 the lanyard tight
Photo 6 the lanyard cleated.
Photo 3 the cleat.
