Yanmar ym13 plus sd20 saildrive "clicking"at low revs
SvenH
28 Mar 2011
The Netherlands
When I run my yanmar ym13 (2gm20) on a sd20 saildrive at "engaged" it clicks, like at every rotation or similar, potpotpot together with clickckickclick. This dissapears when I increase rpms.
Not sure if this is only in forward, or also in reverse.
Is this something that needs investigation or is this sort of normal?
Prop clean?
I think i found it.
The connection between gear lever and bowden cable had about 1 mm room to move sideways.
I think the new engine mounts (last year) resulted in a different resonance, causing the clickediclick where I had non before.
After adding a washer yesterday, no noise today.
