ghostlymoron
I’m trying to understand the Yanmar wiring schematic and in particular how the warning lights and buzzer work. I can see that, when the main isolator and key switch are closed (on), the buzzer is energised and returns to earth along the Y/W wire via a diode to the oil pressure switch which I assume is closed until there is some oil pressure to open it. (closed = low pressure = fault). Similarly, the oil pressure warning light will be on. The temp warning light I assume will be open on start up and so not illuminated. I can’t hazard a guess as to the operation of the ‘charge’ light at all.
When the start button is pressed, the solenoid is energised and hopefully the engine starts thus breaking the circuit through the oil pressure switch and extinguishing the oil light. However, there is an alternative for the buzzer so why does it stop?
There seems to be some magic in the alternator contacts. Could someone explain please?
